Xe-r 228 230 112 +2
Old Oct 9, 2006 | 10:21 PM
pdd's Avatar
pdd
Default Xe-r 228 230 112 +2
Xer 228 230 112 +2
44 Abdc 49 Bbdc Ivo 4 Evc 1
8.72 Dcr
11.31Scr
With A .040 Cometic
61cc
-.006 out the hole
i think it should be a great cam for all around performer for my setup what ya think . i think it will rip.what do you think of the intake bias, is it too intake bias or ok?
Old Oct 10, 2006 | 03:28 AM
PREDATOR-Z's Avatar
That will not be too much of a change from your FM6. Not worth a swap IMO.
1>Ivo
45>Ivc
47>Evo
3>Evc
112>Ecl
4>overlap
Just advance your cam by +1 or +2 and you get even better results.
Old Oct 10, 2006 | 03:42 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
1>Ivo
45>Ivc
47>Evo
3>Evc
112>Ecl
4>overlap
That was my thought...
Old Oct 10, 2006 | 03:48 AM
PREDATOR-Z's Avatar
This is yours on a 112+1 (which i like)
2>Ivo
44>Ivc
48>Evo
2>Evc
113>Ecl
4>Overlap
And on a 112+2
3>Ivo
43>Ivc
49>Evo
1>Evc
114>Ecl
4>Overlap
Old Oct 10, 2006 | 03:53 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
With only 4° of overlap?
Old Oct 10, 2006 | 04:01 AM
PREDATOR-Z's Avatar
What are you asking????
Old Oct 10, 2006 | 04:38 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I thought that you were talking to me earlier. I realized that it was far from my cam specs now.
Old Oct 10, 2006 | 05:58 AM
PREDATOR-Z's Avatar
I was talking about his 226/230 112+0 actualy in his car. I would advance his actual cam +1 or +2 and on a +1 it has better VEs (that I like) than the 228 he suggested.
Old Oct 10, 2006 | 05:20 PM
pdd's Avatar
pdd
thanks for the advice guys
Old Oct 10, 2006 | 09:39 PM
1stz06's Avatar
That was amazing. I didn't understand one thing you guys said. Damn I have a lot to learn.
Old Oct 11, 2006 | 12:00 AM
pdd's Avatar
pdd
LOL yes theres aloooooot to learn
Old Oct 11, 2006 | 12:38 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
x2
Old Oct 11, 2006 | 01:24 AM
pdd's Avatar
pdd
what is the better ivo and evc NA and why??
3 ivo
1 evc
or
3 evc
1 ivo
Old Oct 11, 2006 | 02:50 AM
PREDATOR-Z's Avatar
It is relative to the combo and it cannot be defined as what is best.
In general having your IVO intake biased by 1* from TDC produces good results.
I tend to like mine equidistant to benefit from both sides and carry the power well after peak.
A setup that is too exhaust biased will die of quickly after peak.
Old Oct 12, 2006 | 04:13 PM
pdd's Avatar
pdd
so do you mean
ivo 1
evc 1
or
ivo 1
evc-1
sorry for all the questions just want the most optiable cam for my needs in there and to learn.
a fast street car with good manners
ps :
i cant advance my cam only +1 or i would timing chain only goes in 2 degree advances , so im gonna try an xer grind, a little more agressive
this looks nice to
226 230 113 +1
ivo 1
evo 1
45 abdc
49 bbdc
8.64 dcr
11.31 scr
wit my .040 cometic
Old Oct 12, 2006 | 04:27 PM
Slowhawk's Avatar
LS1Tech Sponsor
I'd do a 228/232 instead with a 112+4.
But,first do a leak down and have the electrical issue's fixed
If you want fun, I've had real good result's with XER 232/238 on 112+2 or even 110+2. Do that,install a wideband (prefer Dynojet) and I'll tune the car SD. (only if it is not spitting body control codes )
Old Oct 12, 2006 | 04:32 PM
pdd's Avatar
pdd
i have my leak down tester but the car only has 9k miles on it, but ill do it. i suspect air was getting sucked in after the MAF causing false readings, causing the car to go into low power mode. i reasembled the intake tract and problem solved after soo loooong and im ******* happy as ****
