Why do you Advance a Cam
360/44 = 8.18 cam degrees, or 16.32 crank degrees. Way too much to advance a cam. If you have a setup that is marginal on piston to valve clearance, advancing the IVO 16* or retarding EVC 16* is almost certain to cause problems.
As stated previously, one crankshaft degree of adjustment requires only .5 degree of change at the cam. This is usually accomplished by an offset bushing that moves the sproket in tiny increments, small movements on an adjustable sprocket, or multiple offset keyways on the crankgear.
Any time you are adjusting the timing, you really need to degree the cam anyway. Yes, you can be pretty sure that a two degree bushing will move the timing two degrees - but is that camshaft or crankshaft degrees - or did you put it in advanced or retarded? Pays to be sure.
