Oil filter leaking...
Old Oct 14, 2006 | 07:54 PM
SPECIALIZED STAINLESS's Avatar
Default Oil filter leaking...
I'm using the larger Mobil 1 oil filter right now before I was using the correct size, different brand and was doing the same thing. I rubbed fresh oil on the seal before putting it on hand tight. And it still leaks about a drop every 1-2 weeks. I know it's not a lot but it shouldn't leak at all. How am I not getting a good seal? Thanks, Steve.
Old Oct 14, 2006 | 08:02 PM
jdoyle's Avatar
i always put mine on more than hand tight. a good amount more than hand tight.
i dont know if what i am doing is right or wrong, good or bad, so take this advice with a grain of salt.
Old Oct 14, 2006 | 08:05 PM
Grimes's Avatar
are you sure there isn't an old gasket stuck to the block? or perhaps some dirt on the sealing surface?
Old Oct 14, 2006 | 08:07 PM
BLKWS.6's Avatar
BIG POSSIBILITY AND VERY BAD!!! CHECK THAT ASAP!
Old Oct 14, 2006 | 08:57 PM
black01_WS6's Avatar
sounds like other have said- a old gasket. Usually when you double gasket it leaks really bad. I would take it off and check for gaskets first.
Old Oct 14, 2006 | 09:08 PM
Ok, thanks. I don't think there's an old gasket but I'll check. Steve
