Hydrolocked the LS1...pics of damage
Cold H2O is a solid
If I recall correctly, H2O (water for us common folk) is one of the few (only?) substances that can occupy all three states of matter.
http://www.chemicalelements.com/show/boilingpoint.html
Also, just as an aside water is slightly compressible. If you're doing calculations that have water, say, 1000 m deep then you could be quite a bit off assuming it's noncompressible. At 1000m the pressure (pgh) will be enough to compress the liquid and change it's density from 997 kg/m^3.
Just to recap, water can be a solid, liquid, or gas. Of course, we all know that. Air can be a liquid at extreme pressures, but is commonly a gas. Both air and water are "fluids". Atleast they were when I took mechanical engineering fluid dynamics, and it hasn't changed. That's why you study flow seperation, turbulance, and aerodynamics in fluids because air is a "fluid".
Air is a gas.
Gases and liquids are the two subcategories of fluids.
<--- Mechanical Engineering Major.....but I learned that in High School....maybe even grade school.
"maybe even grade school". Ben T.
I cant believe its that easy to hydo-lock a stock motor without driving it directly into a lake.
The water was about mid bumper deep and I was merging to an on-ramp and not going very fast. There was enough water splashed up that it sucked past the filter. It doesn't have to cover the lower air box lid.
maybe just maybe
that sucks.....jb weld it
