DIY cam install?
To hold up the lifters, go to wal-mart or something and buy 5/16" wooden dowel rods from the arts & crafts section, right next to the sewing/fabric. Trust me, that is the easiest and cheapest way to do it. I bought some metal dowel rods from home depot first and couldnt get the damn things in, and rather than spending an hour or so trying to use a dremel to grind down the edges on the 2 rods(i dont have a grinder), I tried the wooden dowels. They are made perfectly for this, it won't splinter or crack, just lube it up and work it in, super fast and easy, and you can feel them hit the back of the block. Plus they have some give to them so you can sort of work them in at an angle to start off with since you don't have much room. Worked famously.
I recommend the Crane valve spring tool, super fast doing 2 at a time but the other tool you can look at for $30 is Tim's Tool:
https://ls1tech.com/forums/tools-fabrication/317675-tim-s-valve-spring-tool-now-available.html
Heard nothing but good things about it. I used the TDC method cause it was free and I don't have a air compressor handy and didn't feel like hauling a friends to my garage. Plus it helps to be able to push the valve in slightly so that the keepers go into place while you work on the 2nd valve(crane tool you do 2 at a time). We used a buddys cordless impacts and they made things SO much easier.
For the crank pulley bolt we put it in 4th gear and I have a 3/4" drive set of tools so we used I think a 15/16" socket and a 3/4" drive breaker bar and i slipped a long piece of fence post over that and worked it around the hood, 2 turns with that and finished loosening it with a 3/4" drive ratchet. Super easy.
We took so long mainly cause we had a bunch of friends coming by to check it out, lend a hand, and have a few beers. It was me(im 19) and a friend(16) that did all the work. Initial start up makes it all worth it man, that loud *** lope @ 3am, my neighbors loved it
. The Best V8 Stories One Small Block at Time
the crank pulley is fun, I had to put mine in the oven for 20 before I tried to put it on. If you rush it will fight you
I will PM you when I'm ready to do mine. I'll probably rent the equipment from you just to save some headaches.
When it comes to pulling the cam I have both the JPR tool and the 5/16" steel rods(I wouldn't use threaded rod. Get unthreaded solid rods.) The JPR tool works on some engines, but not on others. For $3.50 each you can't beat the steel rods.
