Spun bearing? :(
If it is a spun bearing I'm prepared to pull the motor, have the block checked and throw in a rebuild kit. Right now the motor just has mild bolt ons. I'm looking to probably throw a 200 shot of nitrous in it, along with a cam in the future. Just looking for opinions about what the best bet is... built motor and swap them? Rebuild kit and throw that in if my block if it's good? One option I'm thinking is just getting another LS1 used (maybe from an '01 or '02) throwing that in, and building my my old motor in the mean time. This will be my first rebuild so I'm looking for any advice people can offer.
Car's a 2000 TA
Good luck!
The car was actually run without the belt for maybe a minute or 2 from a cold start after sitting for a few hours. I'm not dumb enough to run the engine for an extended time with no water pump turning.
just drive it untill it actualy tells some symptoms, otherwise you are just on wild goose chase... wait till the goose is squacking and trying to attack you and then shoot it
Easy on the metaphors man...
Ben
Thanks everyone for the input.
