piston rings washed???
Old Oct 23, 2006 | 11:46 PM
ws.6kid's Avatar
Default piston rings washed???
I dynoed 402 rwhp on a dynojet with a tune. I was at LEAST expecting 450rwhp. The only thing i think what could be holding me back is the rings have not sealed yet. My car smoke prefusely at idle randomly. Im using 10w40 Penzoil SAE oil. Ive changed my oil 4 times already and every time it is black as **** and has gas in it (which I was told was normal). I have 1400 miles on my motor. My car is throwing 2 codes p0125 which is a TPS sensor code and p0135 which is a o2 sensor heater malfunction on bank 1 sensor 1. What other possibilites could cause such a dramtic power loss. I made 400rwhp with just a MS3 before my current setup. All my supporting mods are listed in my sig. Some one please help....
Old Oct 23, 2006 | 11:56 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Sounds like you have the same problem I do. I ran my 347 on the dyno heads stage 1 for nitrous (317 truck castings) and 224/230 XER cam. I put down 358/349 and was having an ***-ton of blowby due to the nitrous rings. Motor runs hard as hell on the street. I know that I was having that problem due to the rings.
What are your ring tolerances?
Old Oct 24, 2006 | 12:20 AM
Patrick B's Avatar
It sounds like your o2 on the driver side header is whacked, either from blow by from rings or it is causing your car to run rich and causing rings not to seat. Is the smoke mainly coming from your driver side or do you have single exhaust. Just a thought, hope this helps.
Old Oct 24, 2006 | 08:43 AM
ws.6kid's Avatar
Im not sure what my ring tolerances are, but HPE said the rings would hold a 250 shot of juice no problem. The smoking mainly comes out my cutout on the passenger side but also still comes out the tail pipes. Like I said it smokes on and off, and never smokes at WOT or cruise. I replaced the fornt o2 sensor because a couple of weeks ago the driver side o2 sensor melted on the header and popped a fuse, which threw everything off. I got all that fixed now and replaced the o2 sensor.
Orangepeel, how did you fix your problem? I also plan on running nitrous.....
Old Oct 24, 2006 | 09:33 AM
ws.6kid's Avatar
Would a exhaust leak cause the drivers side to run rich, killing the o2 sensor, thus not letting the rings seat? Because I'm pretty sure I have a small exhaust leak on the drivers side header.
Old Oct 24, 2006 | 09:43 AM
RedWS6 00's Avatar
May be interesting to log your fuel trims.
If your O2 sensor is giving an odd reading, and it winds up the fuel trims on one side of the engine, then that alone will surely loose you power.
Old Oct 26, 2006 | 12:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I ran a race Evac system. Pulls from the header collector from each valve cover.
Old Oct 26, 2006 | 12:51 PM
ws.6kid's Avatar
Where did you buy that race evac system at? That solved your smoking problem completely? How much did your power increase on the dyno?
Old Oct 26, 2006 | 02:59 PM
ty_ty13's Avatar
7 Second Club
you need to get the AFR and timing decent and then romp on it to make the rings seal... a fresh motor needs this to make the rings seat...
Old Oct 26, 2006 | 03:21 PM
ws.6kid's Avatar
Could this possibly be a PCV issue? I have yet to take off my intake to check for oil. But, would a PCV Problem cause such power loss?
Old Oct 26, 2006 | 03:58 PM
Asmodeus's Avatar
how did your compression test and leakdown test go?
Old Oct 26, 2006 | 04:12 PM
ws.6kid's Avatar
Haven't gotten a chance to do a leak down/compression check yet due to work. Maybe tonight I may be able to. The thing I find weird is the smoke is white thats coming out not blue.... My coolant level is good but its definitely burning oil, I can smell it and my low oil light comes on. It s burning about a quart every 500 miles or so average. It would be awesome if my smoking problems went away after the PCV delete but I don't know till I try it right?
Old Oct 26, 2006 | 06:42 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It could vary well be. That was why I deleted min and ran the race evac. I got it from Moroso. like 30$.
