measure compression ratio
Old Oct 26, 2006 | 06:06 PM
z28drag's Avatar
Default measure compression ratio
i did heads and cam on the car and tuned it with an ls1 edit, my question is, does any one know how to measure the compression ratio of an ls1 and what tools do i need.
Old Oct 26, 2006 | 06:36 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What heads/gasket combo are you running? Are you looking for a static or dynamic number? both?
Old Oct 26, 2006 | 08:11 PM
z28drag's Avatar
actually both, gm gaskets, and custom 228cc heads " 2.02/1.575"
Old Oct 27, 2006 | 05:27 PM
z28drag's Avatar
anyone know
Old Oct 27, 2006 | 05:40 PM
DONAIMIAN's Avatar
We need the volume of the combustion chamber, not the intake port to get the static compression ratio. We need the cam specs to get the dynamic compression ratio.
Old Oct 27, 2006 | 06:15 PM
67Ranger's Avatar
there are no commonly available tools to measure it basically. You just have to figure it out mathematically. You will need to know, displacement, head gasket thickness/bore, deck height, chamber size on heads, and piston dish/dome. So basically, you should post up your head gasket thickness/bore, and chamber size on the heads. I dont know what the normal deck height is, but i would guess 0 to 0.005 for a stock motor.
Old Oct 27, 2006 | 06:21 PM
The stunningman's Avatar
http://www.rbracing-rsr.com/compstaticcalc.html
I used this
pistons are usually .007 out of the hole
