head swap bolt retorque?
Old Oct 27, 2006 | 08:20 PM
StreetLethal01's Avatar
Default head swap bolt retorque?
70 is correct
Old Oct 27, 2006 | 08:21 PM
cjg454ss's Avatar
just did a head gasket change after blowing the first set. im using arp bolts and they have been torqued once. i know you can re use them but i have heard you have to retorque after a heat cycle. is this true? also what is the torque spec. i lost the sheet they came with . so i did 70 lbs. any info would be appreciated.
Old Oct 27, 2006 | 08:50 PM
AppleMac's Avatar
70 lbs with ARP lube. Using ARP lube is very important.
Torque the bolts 5 times before the initial heat cycle.
The heat cycle the car and torque them again.
Note: in between torques you want to loosen the bolt about 60 degrees.
Old Oct 27, 2006 | 08:52 PM
AppleMac's Avatar
Hey you like the Bucs?
Did you see Matt Bryant and Ronde Barber? DAMN!
Old Oct 27, 2006 | 09:27 PM
cjg454ss's Avatar
5 times, like torque then loosen and torque again?
