IMPROVEMENTS To The PRC LS6 Street Heads!!
Old Oct 30, 2006 | 07:51 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I know you've been asked a lot of questions already, but what are the combustion chamber sizes? Are the heads milled at all? The reason I ask is I have a TR224/224 that I love, but want to cut down my quench area but I'm not sure I can do it with my current set of heads. I'm not sure how much they were milled and I'm concerned about PtoV if I were to run a cometic 0.040" set of gaskets.
Old Oct 30, 2006 | 08:37 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Ok guys here we go
the last set that shipped went
.300207
.400 256
.500 292
.600 314
*this was a 2.02 valve setup
You can still get the cylinder head with stock size valves for running large camshafts.
The power output from the two cylinder heads are very similar.
We will still deck any customers head to their requested chamber size. Standard size is 64cc. The stock size valve setups will still be ms4 friendly with the .015" cut off the deck!
I hope I hit everyone's questions.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Oct 30, 2006 | 08:38 AM
With the 2.02" intake valve in the head you will have almost stock clearance! As a result you could run the cometic .040" gaskets & still deck the heads a easy .020" on top of that!!
__________________
Jason
2005 Twin Turbo C6
Old Oct 30, 2006 | 08:41 AM
Ben we use a newen cnc seat & guide machine. The system uses a single point cutter that allows us to instantly change any aspect of the valve job that we want to adjust. As a result we have access to the most advanced machinery when it comes to developing a valve job & tweaking combinations. The current intake port only uses a radiuas at the point the top angle merges into the 90 degree that opens up the chamber.
Originally Posted by Studytime
Jason, can you describe the valvejob? Is it a multi-angled or is it radiused on both sides of the margin?
Thanks guys! Glad to see continuing improvements to a great product already!
Ben T.
__________________
Jason
2005 Twin Turbo C6
Old Oct 30, 2006 | 10:24 AM
DogNutz's Avatar
When can we expect a reflection of this change on the website?
Old Oct 30, 2006 | 06:30 PM
PIMP_2's Avatar
Deleted by Admin. Use the proper forum for Sponsor feedback issues.
Old Oct 30, 2006 | 06:53 PM
KY Z28's Avatar
Originally Posted by PIMP_2
blah blah I used the wrong forum and got my post deleted by Nine Ball
DAMN son, you win the award for the most "colorful" post
on a serious note, I have the "old" style LS6 heads (they are 2 months old or so) so is there a real problem with the rocker arm pedastal breaking? I have only heard of this once on a ported stock casting and I think the guy had a pretty extreme set up.
p.s. LOL the evil CNC monster didnt eat mine thank god! they look bad ***, if only i could have the time to install them!
Old Oct 30, 2006 | 06:54 PM
Fratsit's Avatar
Hey Pimp...
There is a sponsor feedback forum elsewhere on the board. Sorry about your bad luck, but most of us want to keep this on topic.
R/
Frat
Old Oct 30, 2006 | 08:04 PM
PIMP_2's Avatar
It was some very usefull information if your planning on dumping 1100 bones into TSP's heads.
Old Oct 30, 2006 | 08:10 PM
Blue02Ws6's Avatar
I would agree, I think people should be able to post their personal experience in a thread without it having to be in a specific forum. A lot of people would like all the information to make an educated decision and don't always search and read the dedicated forum. Should they, yes, do they....no. I can see if someone got out of hand and started flaming the sponsors but if someone came in and just stated facts I don't see why there should be any problem. I know TSP has had some problems in the past with a couple parts, but they have refunded, swapped out, and to me made things right and continue to push the envelope on performance products at a great price. I didn't start this to bash TSP, hell my car is stitting in their shop right now getting quite a bit of work done. I just think if people act like adults that they should be able to post their experiences with products without it offending the sponsors, and the same goes for the sponsors, I am sure they can take some criticism and figure out how to not let it happen again. This public information sharing will only lead to better products and customer service IMHO.
Old Oct 30, 2006 | 10:31 PM
CHIWS6's Avatar
what would u reccomend for a g5x3/114 w/o flycutting?
Old Oct 31, 2006 | 01:18 AM
  #32
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
These definetly sound like an improvement. Good job TSP.
Old Oct 31, 2006 | 08:34 AM
  #33
Billdog350's Avatar
I just ordered a set of these heads thru a local tuner, CT Corvettes. Hopefully I get the new "hot" ones!!!!
Old Oct 31, 2006 | 08:49 AM
  #34
Sharpe's Avatar
Congrats, TSP! Tightening that price/performance arena even more!
Old Oct 31, 2006 | 09:47 AM
  #35
BQTransAm's Avatar
I am currently running the original Torquer cam, and I like it. Would these heads be a good addition or should I look at something else, like a 5.3 head.
Old Oct 31, 2006 | 11:36 AM
  #36
PAGregSS's Avatar
Very nice. Jason, could you shoot me a PM for applying this to a set of 243 heads that I already have? Also, any larger valve choices? I intend to use the heads on a 408 nitrous motor.
Old Oct 31, 2006 | 03:03 PM
  #37
Fratsit's Avatar
I am with you... I am running the Torquer V3 and am curious as well. These heads or the 5.3's.
R/
Frat
Old Oct 31, 2006 | 03:18 PM
  #38
Billdog350's Avatar
Originally Posted by Jason 98 TA
Ok guys here we go
.300207
.400 256
.500 292
.600 314
Props to PRC/Texas Speed for their awesome results and aggressive pricing!
Here is a comparison to some "trick flow" heads with 2.04" intake valves listed for $2400.
Flowbench Results:
Lift Value Intake Flow Exhaust
0.100 68 55
0.200 142 115
0.300 215 185
0.400 260 230
0.500 300 251
0.600 320 259
Old Oct 31, 2006 | 03:32 PM
  #39
dmiz0420's Avatar
I'm wondering how the 5.3's flow w/ 2.02 intake valves instead of the 2.04
and then that compaired to the 2.02 ls6.
Just when you think your getting to know the products out there they gotta go and do something like this.......
Good job!!!!!!!!!!!!!!!!!!!!!!
Old Oct 31, 2006 | 03:59 PM
  #40
Studytime's Avatar
The new runners are smaller, so I'm guessing it's going to be pretty hard for him to go back in and add aluminum with the new program.
Ben T.
