IMPROVEMENTS To The PRC LS6 Street Heads!!
Old Oct 31, 2006 | 10:48 PM
  #41
Bader-X's Avatar
can ... can ... (oh come on say it)
can I order a set with a 241 casting written on it to fool people?(and anything else written in the front side by a set of a stock gm 241 casting that can be seen when somebody opens the hood and sees the heads from front and side?
Old Oct 31, 2006 | 11:43 PM
  #42
SSilverSSurfer's Avatar
how would these be with a MS3? is flycutting required?
Old Nov 1, 2006 | 06:18 PM
  #43
Camaro99SS's Avatar
That's a great value for worked heads! The bar for cheap performance just got raised yet again.
How do these new LS6's compare to the Terminators in p/v clearance?
Jason
Old Nov 1, 2006 | 07:15 PM
  #44
Zach@Texas-Speed's Avatar
You could always get the 5.3l port ran through the 241 head so nobody could tell I've seen that setup flow 300 @ .600!
Old Nov 3, 2006 | 02:59 AM
  #45
Bader-X's Avatar
same price as the 5.3l? can order on the phone with the same price without a core charge? and if so only 241 or the older casting the came before the 241 are the same with/without a core charge? how much with stock valves (and how much do they flow)?
assuming that if they`re the same price then they`re with the bigger valves like the 5.3l.
but really can`t change or modify the casting on your ls6 heads to say 241 or the older casting numbers and look like 241 or older from the frond and side installed?
Old Nov 10, 2006 | 10:47 AM
  #46
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I have some used 241s I'd sell you for pretty cheap ported & setup. Email or call if you need a set!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Nov 14, 2006 | 07:41 PM
  #47
chriswtx's Avatar
I saw on your website that you can get Race Finishing | Hand-Finished Race Port $250.00. How much flow does that add to say the LS6 stage 2.5 heads??
