Help with 383 cam
Old Oct 29, 2006 | 04:40 PM
1BADAIR's Avatar
Default Help with 383 cam
I have a 383 with -7cc pistons, 62cc 2.055 1.60patriot heads, ls6 intake.
My current cam is a 246 248 .615 .614 114 cam(peaks at 6300-6400)
I am not happy with the cam and am looking for something else.
what should I try.
It will also see a 150-200 shot in the spring
Old Oct 29, 2006 | 06:34 PM
ssam98's Avatar
Default cam
what should I try.
the cam is more than enought, what you need is 225 AFR heads and 90/90 fast combo ported, and I bet you be at 510rwhp and 490rwtq.
Old Oct 29, 2006 | 07:15 PM
1BADAIR's Avatar
If I can afford new heads I will get some but I lost my 6 year job at ford 8 months ago at started at another place about 2 months ago and found out we will be closing nect month.
just trying to get a little more out of it with what I have. Maybe a cam to raise DCR oe something?
Old Oct 30, 2006 | 12:23 PM
ssam98's Avatar
Default tune
do you have a good tune, a good dyno tune makes all the power.
Old Oct 30, 2006 | 12:38 PM
NEVRLIFT's Avatar
What exactly aren't you happy with? Is it peaky, soft in the low-rpm range, something else?
Old Oct 30, 2006 | 10:00 PM
1BADAIR's Avatar
would like something that peaks higher and maybe raise the DCR
