5.3 heads.....should I???
I have the oppurtunity to purchase a set of 5.3 heads from a friend who owns a cylinder head shop here in Michigan. He says they are brand new castings that he CNC ported, 58cc, 2.02/1.57 and flow 310. They have all Manley hardware in them. He says he'll sell them to me for $800. Is that a good price and are these pretty good heads? I have a stock LS1 right now, what's the liters on that...is it 5.7 or something? What do the 5.3 heads come off of? Also, what kinda cam could I run with these heads without having to fly cut the pistons and what potential valve cover problems or any other issues do you see if I decide to run with them. I have an LS6 intake I plan to use on this motor.
Help!
C'mon guys....you're LS1tech.com....you're like rock stars in the LSX world. This one should be easy.
Moving to Internal Engine.
I'm looking for around 410/420 rwhp...370/380 rwlbs of torque. This car will be a street car and I would like to not have any idling issues and a killer lopey sound to it. The car is an A4 with 3.73 gears and 26" tall tires. I already have an LS6 intake that I'm going to use and I plan to stick to with the stock injectors and throttle body.
If I decided to go with the heads, what do you recommend of the following......
1.) Camshaft (without having to flycut the pistons).
2.) Stall Speed of torque convertor.
Thanks for any help you can provide. This is going to really help me out.
gimme 2!
