Almost all the valve springs are broken. WTF!
Old Nov 1, 2006 | 11:03 AM
LostCauseZ06's Avatar
Originally Posted by Billdog350
Warm your car up for 10 minutes every time you drive it? Dude, you must be getting 10mpg! It only takes 20 minutes for me to get to work. If I let my car "warm up" it will take more than 10 minutes just sitting there idling. However if I let it idle 30-60 seconds, and then drive normally and don't rev the car past 2000rpm, the car is warm in less than 3 minutes. Engine oil temps don't get up above 150 until I'm almost AT work.
I just can't see warming up a car for 10 minutes every time you drive it, that's just plain nuts. No way OEM's or even performance products are designed for >10 minute warm up per trip.
LOL im with you... it takes me 15-20 mins to get to work.. i just let it idle for 30 seconds, drive off and quick shift 1-2-3 through the neighborhood and keep it around 1800 RPM's.
Old Nov 1, 2006 | 12:15 PM
GuitsBoy's Avatar
Originally Posted by DONAIMIAN
How will a 7.400 pushrod lessen your preload when the stockers are 7.380?
Because you lose .050 preload when you move from a stock 1.550" base circle to an aftermarket 1.450. You net a loss of .030 preload.
Old Nov 1, 2006 | 03:47 PM
N4cer's Avatar
And isn't he running 7.425's?
Old Nov 1, 2006 | 04:02 PM
1BAD02WS6's Avatar
a guy around here had that same problem breaking the springs. installed the cam a tooth off and his cam (about your size) dinged up the pistons a little and broke a couple of springs
Old Nov 1, 2006 | 04:24 PM
mwill15's Avatar
I broke a 918 about 2 months ago. It completely destroyed my engine. I ALWAYS let my car come to operating temp before driving, and the springs only had about 10k on them.
The spring broke right where you describe, too.
Old Nov 1, 2006 | 05:54 PM
redtail2426's Avatar
yeah something is not right with your setup.I have the same exact cam and i am running PPgolds and 7.4 pushrods because my heads are milled and i am using a cometic. .045 gaskets..You should be using 7.425: pushrods if your heads are unmilled...Something is wrong with your setup.
Old Nov 1, 2006 | 06:17 PM
mvvette97's Avatar
here are some pics of them.
Old Nov 1, 2006 | 06:18 PM
mvvette97's Avatar
we can't find a damn thing wrong. Could it be just a **** set if springs?
Old Nov 1, 2006 | 06:53 PM
Ferocity02's Avatar
Back to the pushrod argument. Not all aftermarket cams have a smaller base circle. The only way to be sure what it is is to measure it. With that said, 7.425" pushrods on a stock sized base circle could break valve springs.
Old Nov 1, 2006 | 06:57 PM
mvvette97's Avatar
I measured the seat height and it measured 1.631. I wasn't using the correct tool to measure so does that even sound right at all?
Old Nov 1, 2006 | 07:04 PM
mvvette97's Avatar
somebody was saying that i may have it a tooth off on timing, well I'm sure it is right because i checked several times to make sure it was right. Also if it was off one tooth wouln't it not run very good?
Old Nov 1, 2006 | 07:33 PM
  #32
dug's Avatar
dug
do you have the original retainers to compare with the ones used? Maybe the retainers you used are too thick and put too much preload on the springs
Old Nov 1, 2006 | 08:07 PM
  #33
mvvette97's Avatar
yea i do, i was looking at them and the comp retainers are a tad thicker
Old Nov 1, 2006 | 08:15 PM
  #34
DaddySS's Avatar
Where did you get the springs? Where are the blue stripes that should be on the 918s?
Old Nov 1, 2006 | 08:16 PM
  #35
dug's Avatar
dug
the longer pushrods and thicker retainers could have done it.
Old Nov 1, 2006 | 08:39 PM
  #36
The stunningman's Avatar
918's installed height is 1.800... I doubt you measured it accurately though.
Old Nov 1, 2006 | 11:08 PM
  #37
mvvette97's Avatar
are these springs supposed to be alot longer that the stock springs?
Old Nov 1, 2006 | 11:30 PM
  #38
dug's Avatar
dug
I dont know. I just installed mine with stock retainers and pushrods. No probs after 25k miles
Old Nov 1, 2006 | 11:35 PM
  #39
mvvette97's Avatar
I think I am going to use my stock retainers also this time.
Old Nov 2, 2006 | 12:24 AM
  #40
HottLS1Z's Avatar
majority of engine wear occurs during the cold start I let mine warm up for at least 10 min espically when its cold outside would you rather loose a few mpg per tank or buy a new motor when it blows under 100K?
MY buddy used to think the same as you and his WS6 died at 52K my 98Z is still alive and perfectly well after more abuse including nitrous then any car should take and i Always let it warm up now it has 146K running strong!
As for those springs I think ur best bet is to call the comp help lie see if they have ever had this happen before and see what they recommend for pushrod size those guys really seem to know there stuff.
