Street Cam Selection
"It's a custom cam made for higher compression. When running cam only, you'll want to advance the cam 2-4 degrees (with an adjustable timing chain/sprocket) for more dynamic compression when running stock heads. If you're running ported heads with high static compression, then the cam can go in dot to dot."
I'm def not an LS1 cam guru, but I agree with him. I think it'll work good in my DD.
Thanks everybody for all you post!
I don't think I've ever seen anyone post up a negative comment about it. Reverse split cam for the win!
https://ls1tech.com/forums/showthrea...ighlight=TR230
That's the latest thread on this cam. There are plenty others.
Ben T.
5.3 /cnc'd heads w/double valve springs
Comp Cams 222/224 @ 566/568 on a 112 LSA
Com Cams 1.75 Magnum Roller Rockers
F.A.S.T 90mm intake with Nick Williams TB
85mm Z06 MAF
Double Roller chain
LS6 ported Oil Pump
Pacesetter Headers with TSP ORY
March Underdrive Pulley
428 RWHP 408 FTLBs Torque
MTI lid
slp maf
NW TB
ported 90mm fast
TSP 5.3l heads stage 2.5
TR224/112cam
hedman hedders
ory
dynmouth
TCI 3500stall
RPM tranny
417rwhp 407rwt
if it were a 6speed it would show more,but im happy with it
It is also inexpensive, which is great, probably the least expensive out of all of these
But I also have the TQR 2 sitting on my work bench begging me to install it.
A good tune will either make your car a fun driver, or a pain in the *** bucking toy.
