Stock crank
Old Nov 4, 2006 | 10:16 AM
whywhine's Avatar
Default Stock crank
How much hp can a stock bottom end hold up too and can you help it much with better bolts ?
Old Nov 4, 2006 | 10:17 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
1200 at the flywheel for the crank.
About 500rwhp is the max I would take the stock hypereutectic pistons.
Rod bolts are always a good idea. They are a rather weak link in the bottom end. Rods are good to around 550-650rwhp.
Old Nov 4, 2006 | 10:56 AM
GuitsBoy's Avatar
+1
good rough estimates here.
Old Nov 4, 2006 | 03:19 PM
whywhine's Avatar
Thanks for the info fellas !
Old Nov 4, 2006 | 03:22 PM
brad8266's Avatar
Therer are guys running 9's on the stock block. The weak links are the rod bolts and the piston ringlands. The crank can take about anything.
Old Nov 4, 2006 | 03:53 PM
whywhine's Avatar
That awsome,sum rods and pistons and i can fly!!
Old Nov 4, 2006 | 03:55 PM
whywhine's Avatar
What rods and pistons are good ?
