What are these do-dads that go on top of the heads?
They're supposed to be steam vent tubes. By the time you have steam you coolant is boiling. Hopefully your cooling system keeps your engine below that point. Those things are the interface between the heads and the tubes which eventually leads to the radiator. You should have noticed something was missing when you were putting your intake back on because the tubes were just lying there on the valley cover not connected to anything. You can't just leave parts off(well maybe your EGR or something else mandated by the EPA) without causing a problem. You need to come up with a better inventory system when you do a tear down. You must have had coolant spraying all over the place once the engine came up to temperature. If you had made this post BEFORE you started the engine you wouldn't have received so much grief.
Dont feel bad vtodd. im like an angry golfer. I break more parts gettin pissed during installs... Its uncontrollable rage syndrome. yeah i have it. and this computers not workin right..........
about the coolant blowing everywhere. i cant say that i know what you are talking about. there was no coolant anywhere. it was just smoke/steam.
also, now you have got me scared again. what tubes are you talking about that i should have noticed when installing my intake again??? there was the front coolant bleed pipe thing that had a pipe going from one head to the next, which is installed, and then there are the 2 little pieces that i pictured that went on the rear corners of the heads, but without a tube connecting them. what are you talking about?
thanks by the way.
todd
Originally Posted by greatwhitess
They don't look like gaskets. They are about 1/16th thick and the shape of the plug. They will usually stick to the heads when you pull the plugs. You will need to get replacements if you can't find them. GL. Don't worry about the mistake. Everyone here makes them. Most just don't have the guts to post their f**kups so others end up repeating the same mistakes.
thanks by the way!
todd
lmao dont feel bad todd, i once gave my cutlass a tune up along with cam, intake and carb swap, got everything back together or so i thought, fired it up and the engine looked like it was gonna roll out from between the fenders it was shakin so hard. after launching a few tool across the driveway, cursing, pacing, and chasing friends down that wouldn't stop laughing at me, i looked under the hood and it turnes out olds motors dont like to run with all 4 plug wires on the left bank disconnected lol. they were just dangling over the valve cover in plain sight, i felt pretty stupid lol. i've been a mechanic all my life, we all have done major screw ups at one point all you can do is laugh. but that made me love that motor more, i dont think my LS1 would fire up in the winter time from a dead cold start after installing a monster cam, with just a tap of the ignition switch on the right side 4 cylinders, not going to try either. but anyway good luck and i hope you fix the problem.
thx for the good words cutlass.
ive got the smoking problem fixed, now iam focused on the overheating issue. cant even get around the block without the temps hitting 300
todd
todd
#32
Originally Posted by csmc711
So, you gonna pony up on what was smoking after the help I gave you, lol??
lol, oh no question about it. i was not careful and left the "do-dads" out! and yes i put coolant back in and its running fine. just off the dyno......not the results i was looking for. posting another thread about it.
todd
