cam/heads
Old Nov 6, 2006 | 05:34 PM
99zmaro's Avatar
Default cam/heads
before i start i know there will be someone that bitches about me to use search button, well i did and didnt get any usefull info.So I have a 99 z with a 6 speed all stock except magnaflow exhaust im looking into doing a h/c package, but really know absolutely nothing about them and wanted some ideas on which one people have and use for their daily driver anything would be appreciated thanks
Old Nov 7, 2006 | 10:26 AM
99zmaro's Avatar
Default ttt
....ttt
Old Nov 7, 2006 | 10:56 AM
SLP4CamaroSS's Avatar
you got longtubes yet???
Old Nov 7, 2006 | 12:42 PM
99zmaro's Avatar
Default longtubes
just ordered pacesetter long tubes and y
Old Nov 7, 2006 | 12:54 PM
what are your goals? emisson issues? want alot of lope? want power etc
Old Nov 7, 2006 | 01:00 PM
Cam02ss's Avatar
there is alot to be considered other than just the heads and cam. you can take a look at my sig to get some ideas of other mods involved...there are options all across the board depending on how in depth you want to go. what are you goals with the car?
Old Nov 7, 2006 | 01:01 PM
Studytime's Avatar
This can be a very rewarding decision if you pick it yourself. Don't expect to hit the search up a few times and know exactly what you want for your car. It'll take a few weeks maybe. I've been learning about cam specs indepth for the last six years, and still don't understand everything. Try and listen to some local cars. Go over to ls1sounds.com and try and get a feel for what you like. Go to our dyno results section and read on power increases.
Picking a cam is like picking a wife. It's going to take a while to decide what you want, what you can tolerate, and what you can't put up with. Expect to make compromises too if it's street driven a lot.
Ben T.
Old Nov 7, 2006 | 01:02 PM
Studytime's Avatar
oh yeah, you asked about heads too. Take and insert " or heads" after each time I said "cam".
Ben T.
Old Nov 7, 2006 | 03:43 PM
bjamick's Avatar
check out texas speeds heads and cam packages they are the bomb when it comes to ls1's!!
