408 install help please.
Old Nov 6, 2006 | 07:47 PM
NOZR1's Avatar
Default 408 install help please.
I wasn't sure where to put this so here it is. Can someone please tell me what size to drill and tap a 6.0 L iron block for the alternator hole? I did a search, but came up with nothing. Everything was moving along very smoothly with my install until we tried to bolt up the alternator. I hope I can do it with the powersteering pump on. Thanks in advance.
Old Nov 6, 2006 | 10:12 PM
JBM's Avatar
JBM
anyone made a template?
Old Nov 7, 2006 | 05:53 AM
99whitews6's Avatar
I never drilled/tapped a hole. Just used the existing 2 holes. Works great.
Old Nov 7, 2006 | 07:07 AM
Z'mnypit's Avatar
Same here... I wasnt even going to attempt to drill and tap into that iron after I got the block in the car. You'll be fine just using the two existing holes..
Old Nov 7, 2006 | 04:13 PM
NOZR1's Avatar
Thanks for the replys fellas. Anyone else drill or not drill their 408?
Old Nov 7, 2006 | 04:51 PM
1QWIKZ's Avatar
using just 2 also
Old Nov 7, 2006 | 06:52 PM
chrismcdaniel's Avatar
i guess LMEdid mine for me, cause there where allready 3 holes.. :dunno:
