Air Pump
Old Nov 13, 2001 | 11:39 AM
The BeaSSt's Avatar
Default Air Pump
Has anyone done an air pump yet? The old timers say they are worth 17 - 20 hp. We have a Moroso 3 vane belt driven pump being installed now. It will pull about 10" from 1 valve cover with a adj. pop off valve on the other valve cover using #12 line. We have welded a baffle inside the valve cover it pulls from so as not to take oil from the valvetrain. It will vent into a catchcan with a breather. We will start at 10" although I am told it can pull up to 15" but you do not want to starve the oil pump. We will also run 7 quarts of oil. I will have some pics up in a few days. Any thoughts?
Thanks
Dave
Old Nov 13, 2001 | 01:38 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Air Pump
Crankcase evac?
GeorgeC, moderator for dragracing has one.
Supposed to be worth some power any built race motor.
Old Nov 13, 2001 | 01:45 PM
The BeaSSt's Avatar
[quote]Originally posted by Pro Stock John:
<strong>Crankcase evac?
Supposed to be worth some power any built race motor.</strong><hr></blockquote>
Yes a crankcase evac system. George can you chime in here?
Thanks
Dave
Old Nov 13, 2001 | 06:48 PM
java's Avatar
From: no stops signs, no speed limits .... on a highway to hell
send me the pictures when you have them, very interested in this mod
Old Nov 13, 2001 | 07:18 PM
Damian's Avatar
LSX Mechanic
[quote]Originally posted by java:
<strong>send me the pictures when you have them, very interested in this mod</strong><hr></blockquote>
Ditto...
Old Nov 13, 2001 | 07:27 PM
Bob2of3's Avatar
Wheels up Director
I think you'd need to bulid your engine with low tension rings to take full advantage of something like this
<img src="images/icons/grin.gif" border="0">
Old Nov 13, 2001 | 09:00 PM
WILWAXU's Avatar
I could see that with a big solid lifter motor, I know that mustang guys use them, but mostly with blown or turbo applications.
Old Nov 13, 2001 | 10:17 PM
Silver Pig's Avatar
I would put a catch can before the vacuum pump with no breather so you can still pull vacuum. I dont like the idea of oil going through the vacuum pump.
Good Luck,
Sean(Pig)
Old Jul 11, 2012 | 09:10 PM
TermnEatr's Avatar
Resurrect that thread! Google search yielded a thread from 2001 Wtf I really gotta upgraded my computer lol...
