my car idles at 500
Old Nov 20, 2001 | 01:14 PM
ShooterSS's Avatar
Default Re: my car idles at 500
Mine idles at about the same after my Vig3200 install. What I've read is that there is a Hex nut on the bottom of the TB that you can adjust to open the TB blade a hair and bump up your idle.
Anyone have any DETAILED info on this? Thanks...
<img src="images/icons/smile.gif" border="0"> <img src="images/icons/smile.gif" border="0">
Old Nov 20, 2001 | 01:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you look at your throttle body, there is a screw under the throttle. It's actually a small torx. it's hard to reach but you can turn it a bit and crack the blade a bit. Too much and you will set an SES lite. I bet it would help you guys. I forget the torx size but Paulie knows.
Old Nov 20, 2001 | 01:25 PM
Matt98SS's Avatar
its a T15 and it works better if you take the TB off, remove that screw from the bottom and RE-install it from the top so you can easily adjust it anytime in the future <img src="images/icons/wink.gif" border="0">
Old Nov 20, 2001 | 01:51 PM
MAXIMVS's Avatar
thanks guys i really appreciate your quick responses! <img src="images/icons/grin.gif" border="0">
fluffy dance!! <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 20, 2001 | 02:02 PM
racer88's Avatar
Khris, I gave you contact info for Bluestreak, it is on our site in the MFBG forum. <img src="images/icons/smile.gif" border="0">
Old Nov 21, 2001 | 12:40 AM
MAXIMVS's Avatar
Default my car idles at 500
my car since i got my 212/218 cam mixed with flp longtubes now idles at 500. however, its always idled low. before it was more like 550. i called the dealership since i have a hookup there. they can probably reprogram my computer and up my idle.
do any other of you fellow A4 drivers idle that low? if so or if not please state your idle anyway
