110 and under LSA/ICL/ECL
I have no drivability issues what so ever. Idle is set at 950rpms and I do not get any surging even at 55mph in 6th. I am very happy with the drivability of this cam.
The cam angles are a byproduct of the valve events perhaps a better question would have been who is shutting the IV around 58 ABDC (seat numbers) or DCR in the 8.8+ range, just thought more would want to comment on the lower lsa's title.
I know there have to be some guys on here running around 106 even if it is a track only car.
more exhaust
more lift?
I'd go with more split. Probably 4-6 degrees between the intake and exhaust, but you may need to change duration too (lower) if going that route.
