Mixing valve springs up? K-motion with Isky?
Welp i don't like the idea but MTI now sells the Isky springs and i need K motion springs to match my other K motions. The tech says the Isky will be fine to replace my broken K motion <img src="images/icons/confused.gif" border="0"> Is there any worry about doing this? Install height different between the two? Who sells the K motions now,so i can order some?
LS1Tech Co-Founder
Shouldn't be any problem. Springs have a simple function, and work independently of eachother. They just keep the valve shut. As long as they do their job, you are good to go.
Same install height on those springs as your current ones.
Tony
Tony
