Which cam sensor?
Old Nov 11, 2006 | 11:34 AM
super10lbz's Avatar
Default Which cam sensor?
I swapped an 02 motor (including cam)into my 98 TA and I'm still using the 98 PCM and intake. Which cam sensor do I use the 98 or 02? I'm running into a 343 code that is causing an SES light, the car is hard to start and doesn't pull hard.
Not sure what cam sensor to use, and if I need to replace it, which year sensor to use.
John
Old Nov 11, 2006 | 12:02 PM
2xLS1's Avatar
What sensor are you using that is setting the code?
Old Nov 11, 2006 | 05:30 PM
DougsfastZ's Avatar
He is using the 98 sensor. We don't know if the 98 sensor is bad or just the wrong one to use on the 02 cam.
Doug D
Old Nov 11, 2006 | 09:02 PM
byler900f's Avatar
i would try an 02
Old Nov 11, 2006 | 09:04 PM
Ferocity02's Avatar
They are all the same.
Old Nov 11, 2006 | 10:39 PM
2xLS1's Avatar
I double checked and the 98 sensor part # is different than the 99-02. I would use the one that matches the year PCM/wiring harness you are using. There is no difference in the reluctors on the cams. Otherwise there would be year specific cams and there are not (aftermarket).
On a side note, I have seen the cam sensor wiring get pinched under the intake manifold before on a reinstall. Might be something to check.
