engine install question
Old Nov 21, 2001 | 05:19 PM
AAron's Avatar
Default engine install question
a how long does it take to remove, and the put the engine back in and second does anyone know labor $ involved?
thanks <img src="images/icons/smile.gif" border="0">
[ November 21, 2001: Message edited by: AAron ]</p>
Old Nov 21, 2001 | 05:29 PM
Damian's Avatar
LSX Mechanic
Default Re: engine install question
Aaron, I am not sure I completely understand the typing in your post, but i'll bite on this one.
It all depends on who is pulling the motor how long it will take. Most "shops" will drop the cradle and pull the motor from the bottom, which takes about an hour. If you pull the motor from the top, it could be a 5+ hr job.
If you are having a shop do your work, I would recommend having a performance shop who are experience with F-bodies drop your motor. They tend to be cheaper and most good shops can drop your motor without breaking a sweat.
Good luck...
Josh
Old Nov 21, 2001 | 05:45 PM
AAron's Avatar
thanks i thought it took longer than that for an engine
labor is what like 40 bucks an hour?
Old Nov 21, 2001 | 06:15 PM
Damian's Avatar
LSX Mechanic
Most shops charge a standard rate of 66/hr for labor.
Old Nov 21, 2001 | 07:26 PM
CMNTMXR57's Avatar
It took me about an hour and a half to 2 hours. But then again, I had a hoist at my disposal. Basically what it amounted to was me removing the three bolts from the front subframe and then support it with jack stands, disconnecting brake and fuel lines, removing my shifter and trans cross member, disconnecting my exhaust, and then slowly but surely lifting the car off the subframe leaving the engine, trans and front suspension all in one piece.
Old Nov 21, 2001 | 08:10 PM
99 Black Bird T/A's Avatar
[quote]Originally posted by DamianLS1:
<strong>They tend to be cheaper and most good shops can drop your motor without breaking a sweat.
</strong><hr></blockquote>
<img src="images/icons/grin.gif" border="0"> <img src="images/icons/grin.gif" border="0">
Rumor has it that Mike at MORE Performance can actually drop an LS1 cradle in less than 30 minutes when his best guy is helping once.
I think dropping an engine and re-installing runs about $900
[ November 21, 2001: Message edited by: 99 Black Bird T/A ]</p>
Old Nov 22, 2001 | 12:10 AM
AAron's Avatar
cool thanks ya'll
