removing AC... ?
Old Nov 22, 2001 | 08:31 PM
PhantomTA's Avatar
Default removing AC... ?
What has to be done..?
Old Nov 22, 2001 | 08:50 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: removing AC... ?
Take the belt off, it's separate.
Bleed off the AC.
Take the parts off.
Old Nov 24, 2001 | 10:08 AM
Dave F's Avatar
An easy 40lb slimfast diet!
Old Nov 24, 2001 | 03:26 PM
QUASAR's Avatar
[quote]Originally posted by Dave F:
An easy 40lb slimfast diet!<hr></blockquote>
That is a good thing to do i would assume for the people that are using iron blocks. Taking the AC off and moving the battery to the trunk should help to return the noseweight back closer to normal.
How much HP should one expect to gain from removing the AC of the belt system? Any before/after dyno #'s?
<img src="images/icons/smile.gif" border="0">
Old Nov 24, 2001 | 09:49 PM
PhantomTA's Avatar
So i could stand to assume aprox 40lbs?
and would this give a similiar effect as an underdrive pulley? less accesory drag? and this could mean quicker revving? but without the negative effect on alternatior charging?
hmmmm i wonder
[ November 24, 2001: Message edited by: PhantomTA ]</p>
