AFR or ETP for A-4
Old Nov 12, 2006 | 03:33 PM
HottLS1Z's Avatar
Default AFR or ETP for A-4
Im looking at doing a set of heads this winter and was wondering what would be a better choice for my mods the AFR heads or ETP I keep hearing good info on both the only differences there will be in my mods in sig is a stage 3 trans with a 4400 stall. I want better 1/4 times and would like to pick up some mid range too and raise the compression so I was thinking 59cc sound right?
Old Nov 12, 2006 | 07:47 PM
HottLS1Z's Avatar
anyone?
Old Nov 12, 2006 | 08:46 PM
GOGO's Avatar
I purchased a set of ETP's. I had to send them back because the exhaust ports were not completely finished. They are taking care of the problem. The only issue is the wait. With ETP's you have greater P to V clearance. They are both a great set of heads. You really cannot go wrong with either set.
Old Nov 12, 2006 | 08:51 PM
Louie83's Avatar
I'd go AFR's and a 90/90 port-matched by Tony or TFS and a 90/90 port-matched by Ron.
Old Nov 12, 2006 | 11:38 PM
HottLS1Z's Avatar
90/90 port matched? u meant the intake and TB? im not sure who Tony or TFS is...
