Does HOTCAM need higher rev limit?
Old Nov 24, 2001 | 08:33 PM
TheZman's Avatar
Default Does HOTCAM need higher rev limit?
I'm still trying to make a choice on which cam to go with. The HOTCAM looks like a lot of cam for the money! Does it raise the powerband up in the rpm range much? What should i shift at, and what should i set my rev limiter too?
Old Nov 24, 2001 | 09:53 PM
Brother J's Avatar
Default Re: Does HOTCAM need higher rev limit?
The Hotcam is indeed a lotta cam for small money. The power band will be raised slightly. I shift at 6200 and have the rev limiter set at 6500. What I noticed more though, was the very flat torque curve.
Old Nov 24, 2001 | 10:51 PM
BIGBOS's Avatar
Yea, dyno it to find out where you make the most HP
Old Nov 25, 2001 | 01:49 PM
BIGBOS's Avatar
What other kind of input...it has a flat torque curve and gives you some impressive power uptop...do a search of the dyno #'s some guys have been getting
Old Nov 26, 2001 | 12:46 AM
TheZman's Avatar
SWEET!! Thanks guys!!!
Old Nov 26, 2001 | 12:48 AM
TheZman's Avatar
Come on guys, we need more input!!!
Old Nov 26, 2001 | 08:17 AM
JC's Avatar
JC
Yes. The HC needs a higher rev limit.
I initially tested the cam at the 1/4 shifting at the stock limit and I trapped 110 (same as B4 the cam swap)
After raising the limiter I now trap 115!
My best dyno has been 364/363
HP peaks at 6k but, I make above 350rwhp from 5500 to 6400rpm(which is where I shift) my limiter is 6600
I make 350rwtq starting at 3900
Old Nov 26, 2001 | 05:55 PM
TheZman's Avatar
Thanks JC!!!
