valve spring tool, were can i get this
Old Nov 13, 2006 | 01:59 AM
zrater's Avatar
Default valve spring tool, were can i get this
do i need one or can you rent or buy one.............
Old Nov 13, 2006 | 05:28 AM
vettenuts's Avatar
Best tool out there in my opinion is the Crane tool, Vinci has it as a web special for $89. Does two springs at once and was designed to do the rear cylinders on an f-body where you can't see back there very well.
Old Nov 13, 2006 | 08:05 AM
HeapaShifter's Avatar
Tim's tool works really good and is only $30. You can find it in the tool section of this site.
Old Nov 13, 2006 | 01:54 PM
gillbot's Avatar
crane tool hands down, it's well worth the extra $
Old Nov 13, 2006 | 02:33 PM
FL Junkie's Avatar
advance has a compression type-ampro for 20 bucks. works better than the claw type
Old Nov 13, 2006 | 04:43 PM
vettenuts's Avatar
You have to be careful of the claw type on some springs. For example, if they are nitrided or shot peened and you scratch up the surface, you have basically ruined the surface treatment.
Old Nov 13, 2006 | 04:51 PM
Cop Car's Avatar
flat piece of steel thats cut (think metal not sheet metal) a threaded bar and a nut is all you need. i wouldnt use a claw type, and im not sure you could fit one back in there either
Old Nov 13, 2006 | 04:56 PM
Happy Jim's Avatar
Echo this approach - I did it on mine - about 30pence for the tool and 10 mins of hacksaw/drilling
Jim
Old Nov 14, 2006 | 08:36 AM
LS1Beginner's Avatar
Crane tool - I found that I had to use the upper plate upside down with the larger diameter valve springs (on the Patriot heads) or I couldn't get the keepers in. The openings weren't large enough. Made the job easy when working in the car.
