Bore to Stroke Ratio Observations
Tangent - do you think the LS series of motors will ever be used in Winston Cup? Maybe in 4 or 5 years to replace the SB2? I guess the C5R block would be a good place to start if you were going to build a 358 ci Cup car motor.
J.
When the pin and piston hit the counterweights.
<img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
<strong>""Opinions on how much stroke is too much.""
<img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> </strong><hr></blockquote>
That just means you need a longer rod! <img src="images/icons/grin.gif" border="0">
J.
<strong>Does anyone have any thoughts on how well the LS1 oiling system will be able to support the high revs of a 4" bore/3" stroke?</strong><hr></blockquote>
I have three words for you: Oil restrictor pushrods.
Yeah unfortunately GM stuck the LS1 with a Ford Cleveland, Buick 3.8 V6, style oiling system. I'm pretty sure that the C5R Corvettes run a dry sump oling system that totally eliminates the problem of the oil pooling up in the valve covers at high rpm.
Yeah the C5R uses dry sump, Katech sells them for only 2485.00.
<strong>
</strong><hr></blockquote>Is the $2,485 for just the oil pan, or the entire system?
But technology marches on, and today's V-10 F1 engines have bore/stroke ratios approaching 3:1, with nearly flat combustion chambers. The 998cc 996R takes another step in that direction with a 100mm bore and 63.5mm stroke, equating to a bore/stroke ratio of 1.57:1, and valves angled at a shallow 25 degrees. Figures that, not coincidentally, are nearly identical to those of Honda's RC51.
<strong>Explain oil restrictor pushrods please</strong><hr></blockquote>
They are pushrods with smaller holes in each end than stock. This restricts the amount of oil that goes to the rockers, thus keeping more in the bottom end and oil pan where it belongs.
The main engine in this locomotive is a General Motors EMD 710 series engine. The "710" means that each cylinder in this turbocharged, two-stroke, diesel V-12 has a displacement of 710 cubic inches (11.6 L). That's more than double the size of most of the biggest gasoline V-8 car engines -- and we're only talking about one of the 12 cylinders in this 3,200-hp engine.
<strong>HEHE This is HUGE!!!!!!
The main engine in this locomotive is a General Motors EMD 710 series engine. The "710" means that each cylinder in this turbocharged, two-stroke, diesel V-12 has a displacement of 710 cubic inches (11.6 L). That's more than double the size of most of the biggest gasoline V-8 car engines -- and we're only talking about one of the 12 cylinders in this 3,200-hp engine.</strong><hr></blockquote>
Only 3,200 hp from a 8,520 cid engine? What a waste, that's almost as bad as a F*rd engine. <img src="images/icons/wink.gif" border="0"> <img src="images/icons/grin.gif" border="0">
I'd like to see the size of the Turbo on that thing. Next thing ya know, somebody will be trying to strap that onto a 3.8 Buick.
[ November 28, 2001: Message edited by: 2quick4u ]</p>
There are V16 Locomotive train engines that redline at 900 RPM and make 5000HP. The intake valves are about a foot and a half long.
For what its worth... In a Locomotive train engine, the Diesal motor turns an electric generator, which turns electric traction motors, generating 10s of thousands of pounds of thrust.
The generator coils are so big you can walk through them.
<strong>what about the iron block 409? What is it's bore and stroke? I am looking to build one of these for nitrous. What about the 375, would that be a good one as well?</strong><hr></blockquote>
The 409 truck block motor is 4.030" bore by 4.0" stroke. This is a very nice combo, but PSJ's combo is 418 and shouldn't cost anymore to build. The 375 is 4.060" bore by stock 3.62" stroke.
<strong>I am going to running a lot of juice on the motor and I heard that with a poweradder that you only want to go .030 over on an iron block. Is that true?</strong><hr></blockquote>
Yes, that is true. You'll want to keep a thick cylinder wall so that it won't crack or distort under the extra cylinder pressure N2O will give.
