Bore to Stroke Ratio Observations
Old Nov 29, 2001 | 12:21 AM
  #41
Godspeed's Avatar
Default Re: Bore to Stroke Ratio Observations
I think it's just the pan actually, I see the idler pulley listed seperately. I wonder what else would be needed for a conversion.
Old Nov 29, 2001 | 12:40 AM
  #42
Crazyquik's Avatar
Explain oil restrictor pushrods please
Old Nov 30, 2001 | 01:11 PM
  #43
84ZZ4's Avatar
Also, keep in mind that two engines with the exact same bore and stroke ratio won't have the same rpm capabilities.
350 SBC has a 4" bore and 3.48" stroke. That's roughly a 1.15 B/S ratio. An engine built with a 400 block (4.126" bore) and a custom crank (say, 3.6" or so) would have a roughly similar B/S ratio, but all things being equal, the 350 will rev higher because the pistons are smaller and have less mass (and therefore less momentum). In order to get equivalent rpm capability from the hypothetical 400-based motor in the example above, you'd hvae to find pistons and rods that wieghed roughly the same as the ones in the 350.
