Building up the bottom end?
Old Nov 28, 2001 | 10:47 AM
bdubb's Avatar
Default Building up the bottom end?
What are some of the engine builders doing to build up the bottom ends of their blocks for the big cube motors?
I already have Katech main caps and the main cap studs have been increased to a larger/stronger stud. Has anyone heard of any major problems with the bottom ends in a 6.0L block with A LOT of power and reving it up around 6500 or so?
Just wanting to check and see if I can do anything else to build it up before I move onto the next stage of the project.
Thanks
Old Nov 28, 2001 | 09:00 PM
Marty's Avatar
Default Re: Building up the bottom end?
ttt
Old Nov 28, 2001 | 10:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
LS1 does not like tight main bearing clearance per Nick @ ARE.
My 6.0 setup is bored .060 over.
Old Nov 29, 2001 | 11:15 AM
MelloYellow's Avatar
What in the above would cause a tighter bearing clearance?
