Bore Question
Old Nov 28, 2001 | 06:13 PM
Marty's Avatar
Default Bore Question
What is the largest bore you can put on a 6.0 block w/o sleeving it? I have heard like .060. What would the ci be on a .060 over 6.0 block?
Thanks,
Marty
Old Nov 28, 2001 | 06:23 PM
RyanJ's Avatar
SSU Moderator
Default Re: Bore Question
i wouldnt go bigger than .060. The blocks arent perfect. with the stock crank thats 375cid.
Ryan
Old Nov 28, 2001 | 07:14 PM
383LQ4SS's Avatar
right, .060 over for a total of 4.06 and thats only after being sonic tested to see if there is enough material. Thats as recomended by Nick Agostino. He did my motor.
Old Nov 28, 2001 | 07:16 PM
Crazyquik's Avatar
Plus you can have the stock crank offset ground for ~10-11 more ci.
Old Nov 28, 2001 | 08:33 PM
Marty's Avatar
Thanks for the help guys
Marty
