New info on GM PCV valve fix....
Old Dec 5, 2001 | 07:10 PM
LS1JM's Avatar
Default Re: New info on GM PCV valve fix....
Guys, the part# on the valve is 12572717. It's just a "hollow" PCV valve..Joe
Old Dec 5, 2001 | 07:15 PM
Big Mike's Avatar
Very good to know. Definitely keep us updated and provide a part # too!
Old Dec 5, 2001 | 09:53 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I know Im getting blow by from the pvc because when I did my ls6 intake on monday I could see oil buildup in my throttle body as well as in the intake runners of the cylinders.
I'm guessing that this isn't helping make any power, so what can I do to eliminate it?
PSJ, did I understand correctly that you just plugged yours? Does that throw any codes?
Old Dec 16, 2001 | 08:09 PM
LS1JM's Avatar
Ok guys just got back from the track and checked my oil level since the new valve. It is still 100% full. (its usually down 1 quart after a weekend of racing)It looks like so far the valve is doing the trick. I will keep you guys posted. Joe... <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Dec 16, 2001 | 08:22 PM
LS1 Mopar Turbo's Avatar
So this would replace the "mod" I have made with some fuel filters? <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
[ December 16, 2001: Message edited by: LS1 Mopar Turbo ]</p>
Old Dec 16, 2001 | 08:45 PM
mmiller's Avatar
Texas Director
[quote]Originally posted by LS1JM:
<strong>Guys, the part# on the valve is 12572717. It's just a "hollow" PCV valve..Joe</strong><hr></blockquote>
LS1JM,
Is this all you did? Just switch out PCV valves, and your oil consumption was eliminated? No other things done to the car?
Old Dec 17, 2001 | 09:22 AM
mmiller's Avatar
Texas Director
ttt
Old Dec 17, 2001 | 06:50 PM
LS1JM's Avatar
Guys, I just switched out the normal PCV valve for the new part #. No other changes...Joe.. <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Dec 17, 2001 | 07:38 PM
02 'Hawk's Avatar
so what's the down side to this PCV vs the OEM piece?
Old Dec 19, 2001 | 09:21 PM
Swills00Z's Avatar
Anymore updates? I too have oil film on my throttle body....
Old Dec 19, 2001 | 09:28 PM
02 'Hawk's Avatar
took mine apart today as i put on the baker hose. it's spotless, but I'm still following this with interest. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Dec 19, 2001 | 09:35 PM
  #32
Swills00Z's Avatar
wtf is the baker hose <img src="images/icons/confused.gif" border="0">
  #33
01Z0H6's Avatar
Do your LS1's consume oil???
I change my oil/ filter religiously with Mobil1 5/30 every 4K!! I have yet to see ANY oil used in that time frame. Mine is also a daily driver!!You guy's must race yours quite often. Or you just give em hell!! <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" /> "Not that it's a bad thing"!! <img src="gr_grin.gif" border="0">
Old Dec 19, 2001 | 09:47 PM
  #34
02 'Hawk's Avatar
[quote]Originally posted by Swills00Z:
<strong>wtf is the baker hose <img src="images/icons/confused.gif" border="0"> </strong><hr></blockquote>
silicone hose connecting the MAF and the TB. Had to cut off about 1/2" on mine to make it so the lid would go back on. It's smooth, not an accordian like the OME piece.
Old Feb 14, 2002 | 10:37 PM
  #35
Swills00Z's Avatar
Everyone still happy with their pcv valve fix?
Old Feb 15, 2002 | 08:22 AM
  #36
227Hawk's Avatar
The only down side is a constant vaccum leak
to the pan.Smaller orifice size is why this
does not show up as increased RPM's This will
show i'm pretty sure as a drop in vaccum <img src="gr_sad.gif" border="0">
Old Feb 15, 2002 | 08:39 AM
  #37
LS1JM's Avatar
My oil consumption has been cut down alot but I still use a little oil though...(half a quart per 3000 miles)Joe.
