burnt valve questions...
1. what does a burnt vale look like
2. can i just get new valves or do i need to do seat work,
compression test shows just slightly lower than all others on that side of the engine. will anything eles cause a misfire other than what ive talked about, maybe injector.
ps somtimes the ses light comes on but dont flash, all stock motor ecept n20 please im out of ideas <img src="images/icons/mad.gif" border="0">
Doesnt sound too good to me.
Try the choo choo test. With the car idling, remove the oil fill cap and put your hand over the hole. Feel a pulse?
If not, when that cylinder is at TDC, run a straight edge over the other closed valves and see if a valve on that cyl. is lower (can slip paper in, can slip a feeler guage in, etc.)
What happened during your driving right prior to this?
Hmm? Hmm? Hmm? ;-)
chris
fully recovered previous n2o addict
Chris
