HELP! is this normal ???
Old Dec 1, 2001 | 08:49 PM
LS1 JAY's Avatar
Default HELP! is this normal ???
While I was at the track tonight my battery almost died(98%) I barley got it to crank after 3 tries! when I did I pulled up to the line and ran almost 2 tenths worse and 2 mph slower then my last 3 runs tonight!!!! then I noticed that it was idleing high around 1,000 rpm's in drive, the clock re-set to 1:00pm (it was 8:30pm) could the computer have re-set and thats why it ran so much worse and why it was idleing higher????? after a 10 mile drive and shuting it off and re-cranking it the idle sems to be slowly returning to normal, is this the computer re-learning?????????? <img src="graemlins/gr_images/icons/mad.gif" border="0" alt="[very mad]" />
Old Dec 1, 2001 | 09:46 PM
LS1 JAY's Avatar
Default Re: HELP! is this normal ???
TTT!
Old Dec 1, 2001 | 10:31 PM
LunaticTA's Avatar
Wow, that does really sound like the idle re-learn, but I have no idea why you would be having problems with charging at the track..
This sounds like a connection issue, I would check the connections on the battery and alt.
Chuck
Old Dec 2, 2001 | 08:21 AM
LS1 JAY's Avatar
TTT! <img src="graemlins/gr_cry.gif" border="0" alt="[whiner]" />
