rev limiter bent pushrods?
<strong>I hit the rev limiter on my 1-2 shift,could I have bent my pushrods,what is the easiest way to check the pushrods.THANKS</strong><hr></blockquote>
What makes you think you bent the pushrods? Any unusual noises like loud ticking? I've hit the rev limited a couple of times and when I've had the car dyno'd they hit the rev limiter each time.
The only ticking sound I have right now is a ORP leak..
Bent pushrods are usually caused by accidently downshifting at high RPM.
I have several for paper weight on
my desk at work..
http://ls1info.com/article.php?sid=97
<strong>its a ticking sound,the car runs strong but after I drive it for a while I dont here the noise only does it when cold</strong><hr></blockquote>
Are you sure that it's not piston slap? Maybe you're just paranoid and are listening for every little noise now. You most likely had the same ticking sound before you hit the limiter. FWIW, I've tagged the limiter quite a few times in my SS with no problems. The RPM's aren't going to hurt your engine, but sitting on the limiter for a LONG time may bend a few. My shift points are at 6,200 RPM, FWIW.
The easiest way to find out is to pull the pushrods out and roll them across a flat surface. It's no big deal to do. The rockers are shaft mounted, so just pull them off and pull the pushrods out. When you're ready to go back together with it, torque the rockers down to 22 lb./ft. of TQ. I had to adjust the valves on my '98 T/A more than once, so I know just how much fun it will be to get to all of those valve cover bolts. If ya have any problems, post up in the southern section for Joseph. He's the moderator over there, and he works for Scoggin-Dickey, so he might be able to help ya out.
[ December 02, 2001: Message edited by: Trevor D ]</p>
<strong>You damage pushrods when you miss a down shift and get into a forced-overrev condition.
Dave</strong><hr></blockquote>
...or, if you should happen to run the motor up anywhere near redline and also happen to have weak valve springs!! Can you spell v-a-l-v-e f-l-o-a-t?!? Valve float on an LS1 = bent pushrods! Been there, done that!
Best regardSS,
Elie
98 Camaro SS #C07
Dave
<strong>There is little chance that you bent pushrods by hitting the rev limiter. We run those suckers to 7000rpm in our race motors with no problems.
i have to dissagree. we just went and looked at a friend of mine t/a A4!! and he had some also almost all bentit was cuz of the hitting of the revlimiter too much. yes you can bend pushrods with only hitting rev limiter.
also you donot have to totally remove the rocker arm. just loosen it up and turn it and you have access to the pushrod with out having to remove other stuff and have the chance of getting the arm to cylinder mix up.
