How much Xtra timing do you get with a HPP3 ?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have a 99 Formula with a Superchips tunner know. And I did the dumb thing of of selling the HPP3 with out keeping a log with the HPP3 on my Atap before I got the Superchips tunner <img src="images/icons/frown.gif" border="0"> my question is were is the timing usually at on the HPP3. Mine is at 27 with the Superchips and goes up to only 40.5 or so I could of swore the HPP3 gave me up to 44.5 or so and was at 28 but im not possitive. please post your timing numbers with a HPP3.
thanks,
Mike H.
[ December 02, 2001: Message edited by: Street Racer ]</p>
thanks,
Mike H.
I can shift faster than you.
You only want to worry about timing at WOT (100% TPS). I saw 29* timing w/ hpp3 and stock MAF. This is up about 1.5* compared to stock tuning.
Jason
Jason
Yes, look at timing at WOT. With stock tuning, timing would start at 25-26 and climb to 30.5. With HPP3 non-rfg tuning, timing will start at 28-29 and climb to 30.5.
[quote]Originally posted by Jamie99TA:
<strong>Yes, look at timing at WOT. With stock tuning, timing would start at 25-26 and climb to 30.5. With HPP3 non-rfg tuning, timing will start at 28-29 and climb to 30.5.</strong><hr></blockquote>
Jamie, do you have a stock MAF? The most my car would see (as well as others) w/ stock maf and tuning would be 27.5* max timing at WOT.
Jason
Jason
Please pardon my ignorance everyone, but what is "timing" on the engine? Could someone elaborate? Thank You!!
<img src="images/icons/smile.gif" border="0">
[quote]Originally posted by The Dragon:
<strong>Please pardon my ignorance everyone, but what is "timing" on the engine? Could someone elaborate? Thank You!!
<img src="images/icons/smile.gif" border="0"> </strong><hr></blockquote>
Timing is simply when the ignition system fires the spark plug.
The faster a pistons velocity is the sooner the spark has to fire to insure maximum downforce is on the piston during combustion. This is where the term "advance" comes in. Too advanced spark, and you get pre-ignition. Too retarded spark delivery and the majority of the stroke going down is not forced down, because the mixture is ignited with too much space during the maximum burn of the mix. for instance when its said that 30 degrees of timing is good, then that means you are firing 30 degrees before top dead center. As RPM's slow, so does the time to fire. Say around 20 degrees mabey.
[quote]Originally posted by kewlbrz:
<strong>
The faster a pistons velocity is the sooner the spark has to fire to insure maximum downforce is on the piston during combustion. This is where the term "advance" comes in. Too advanced spark, and you get pre-ignition. Too retarded spark delivery and the majority of the stroke going down is not forced down, because the mixture is ignited with too much space during the maximum burn of the mix. for instance when its said that 30 degrees of timing is good, then that means you are firing 30 degrees before top dead center. As RPM's slow, so does the time to fire. Say around 20 degrees mabey.</strong><hr></blockquote>
Very cool! Thank You! <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
So what's the ideal timing for the LS1 at WOT??
Considering my modest mods <img src="images/icons/blush.gif" border="0">
<strong>
Location: Live Oak, FL - in the woods where the creatures lurk.
On a basically stock car, I saw no increase in timing w/HPP3, but lots of KR.(this summer)
I think "ideal" timing is a subject for debate, judging from some posts I've read where people picked up HP with LOWER timing. My answer for that would be whatever timing works best for the individual engine.
LS1Tech Premium Sponsor
Just to add fuel to the fire, ideal timing for a '98-'00 LS1 will be different than ideal timing on an '01+ LS1 due to the different cam. I was seeing 25 degrees at WOT stock in my '02. I added a set of fully ported stock MAF ends, and I gained 0 HP on the dyno and showed no improvement at the track. The MAF added a solid 2 degrees of timing.
On my '98 T/A, I showed 25 degrees of timing stock and 29 degrees with the HPP3 non-RFG tuning. I picked up 5 RWHP on the dyno with the added timing.
Trevor, Thanks for the help you have been giving me this past few month's with the car <img src="images/icons/smile.gif" border="0"> Mike H.
[ December 04, 2001: Message edited by: Street Racer ]</p>
