Take a look at this...
Old Dec 4, 2001 | 07:06 AM
LJ_Z28's Avatar
Default Take a look at this...
I was chatting with an import guy and he said he would like to try this combo on an LS1. He installs turbos, superchargers, and nitrous on several LS1 equipped vehicles. He has a good knowledge of turbos and engine management software. He made a 240SX hit high 10's on drag radials so that is pretty impressive.
Well he said he would like to see an iron block bored out to 4.030" and change the stroke to 3.375". He says this is about 345 cubic inches.
He would like to do a twin turbo or single turbo set-up and use Speedpro to do the engine managing.
He says destroking it will allow it to rev higher and produce some really good top end. He says someething like that would be a good highway monster.
He did say the drivetrain would need to be modified extensively for the horsepower it will create.
He said if I was interested in something like that I should go to a M6.
I was just curious of what yall think about this.
Old Dec 4, 2001 | 01:12 PM
2quick4u's Avatar
Default Re: Take a look at this...
[quote]Originally posted by LJ_Z28:
<strong>4.8 truck crank???
Will that fit in the 6.0L block???
What stroke is it???</strong><hr></blockquote>
The 4.8L stroke is 3.268" which would give you a 333 cid engine with a 4.030" bore. Bore to stroke ratio would be 1.23 or the same as the old Gen I SBC 327cid engine.
[ December 04, 2001: Message edited by: 2quick4u ]</p>
Old Dec 4, 2001 | 05:43 PM
wicked 98z's Avatar
Carlos could you send me the name and number of the guy your talking to. I want to see how much it is all going to cost. I dont know how long my motor is going to last under boost.
ALbert
Old Dec 4, 2001 | 05:48 PM
LJ_Z28's Avatar
Albert, I am kind of weiry about that set-up for the simple reason it has not been done yet and the guy is not cheap.
If you still want the info, send me an e-mail and I can give ya more details...
Old Dec 5, 2001 | 12:04 AM
Y2K_WS6_T/A's Avatar
<strong>Well he said he would like to see an iron block bored out to 4.030" and change the stroke to 3.375". He says this is about 345 cubic inches.
I was just curious of what yall think about this.</strong><hr></blockquote>
Hmmm....Will he do the work for free, if I supply the parts? I could always change the Motor Combo, but I thought no matter how high you revved the motor to, it would top out due to Intake limitations and/or Heads not flowing enough air. Sig Check.
Old Dec 5, 2001 | 12:11 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you get serious look into a 4.8 truck crank. Or get an aftermarket one.
Old Dec 5, 2001 | 12:52 AM
LJ_Z28's Avatar
4.8 truck crank???
