MAFT Question
Old Dec 6, 2001 | 07:20 AM
77jimmy's Avatar
Default MAFT Question
Just for clearification so I know I am not going crazy, if my Ltrims are positive which way do I adjust the base settings according to the MAFT chart supplied with the translator. Also, if my O2s are rich which way do I adjust the WOT settting? The car is giving me some weird feedback and I just want to make sure it is the weather change that is doing it.
Thanks,
Matt
Old Dec 6, 2001 | 07:24 AM
TA_2001's Avatar
Default Re: MAFT Question
Here is a bit of info that I stored.. on MAFT..
http://ls1info.com/article.php?sid=163
Old Dec 6, 2001 | 08:02 AM
77jimmy's Avatar
Thanks, that clears up the WOt but it is very vague on the base settings. I am really looking for something that says if the Ltrim is positive then the adjust the base setting this way and vise versa.
Old Dec 6, 2001 | 01:33 PM
Fulton 1's Avatar
Matt,
If you are showing positive Lterms it means that the PCM is adding fuel to the base map. To bring the Lterms down (i.e. moving toward zero/negative values) then you need to richen your MAFT's base setting.
