fuel injector install????
Old Dec 6, 2001 | 05:54 PM
Slow Z28's Avatar
Default fuel injector install????
planning ahead for the turbo...
how easy are they to install yourself? what is needed to be done to the car if i go to 42lb injectors? custom programming? anything? thanks.
Chris
Old Dec 6, 2001 | 06:58 PM
Matt98SS's Avatar
Default Re: fuel injector install????
easy to install, pull the fuel rail and swap out the injectors...its that easy really
you will need custom programming
Old Dec 6, 2001 | 07:34 PM
Slow Z28's Avatar
thanks matt. doing a cam at the same time, so custom programming isn't that big of a deal.
Chris
Old Dec 6, 2001 | 10:17 PM
Dave F's Avatar
sometimes the harness is difficult to get loose. You push the wire clip "in" and pull the connector off. Then the injectors simply slide into the intake with an o-ring to seal everything. Make sure you don't overtorque the injector rail bolts.
Dave
By Brett Foote | 2026-06-04 05:00:17
