Oil comsumption problem after cam install
Old Dec 6, 2001 | 08:08 PM
NicD's Avatar
7 Second Club
Default Oil comsumption problem after cam install
Hi everyone,
I had my thunderracing cam installed about a month ago. Ever since than its been using a lot more oil than before. Is this common for an aftermarket cam? What could have happened during the install to cause this?
Thanks for putting up with my stupid questions,
Nic
Old Dec 6, 2001 | 08:18 PM
BIGBOS's Avatar
Default Re: Oil comsumption problem after cam install
What size cam and how much oil?
Old Dec 6, 2001 | 11:57 PM
Plan B's Avatar
Pop your rocker covers off and check the valve guide seals I had 5 lift up on my new heads. Now I run the new type that sit under the spring.
Old Dec 7, 2001 | 08:45 AM
NicD's Avatar
7 Second Club
Its the thunderracing 224/.561/112 cam. It never really used oil before the cam and I have about 18k miles on it. Now after the cam it seems I am using a quart every 1k miles. I am running factory heads. What are the valve guide seals? How do I check them? I don't know much about the heads.
Old Dec 7, 2001 | 11:18 AM
NicD's Avatar
7 Second Club
ttt
Old Dec 7, 2001 | 11:29 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Do you get a lot of smoke on start up after it's been sitting a while?
If so, it could very well be valve seals...
Old Dec 7, 2001 | 11:48 PM
peter d's Avatar
if your new cam has a lot more lift ,then its possible that the spring retainers are hitting the valve stem seals.
Old Dec 8, 2001 | 12:29 AM
NicD's Avatar
7 Second Club
No, it doesn't really smoke on startup. It does smoke a bit when I jump on it though. Just trying to figure out what could have happened during the cam install to cause this.
