I'm reverse cooled baby~~~
a hose from the driver side of the radiator to the water pump, up to what would usually
be the outlet side of the stock water pump. I then removed the wheel from the stock water pump, leaving the water pump pulley intact. Heater hoses and everything else remains stock, with one minor change to the stock thermostat.
The install came out much cleaner than I expected! You can't even tell that anything has been done to the cooling system. I did a bit of test driving, and the car is staying a nice constant temperature on the gauge, and the heater is nice and toasty. Dyno testing coming Sunday, assuming nothing breaks before then. <img src="images/icons/wink.gif" border="0">
[ December 07, 2001: Message edited by: Terry Burger ]</p>
Can you give more details on what you did? Is your belt bypassing the waterpump altogether now or is it acting like an idler pulley? Did you remove the guts of the waterpump?
What is your coolant temp and what Tstat are you using?
Thanks,
Chris
CSI universal water pump: $239
2 fittings for 1 1/2" hoses: $32
2 water hoses: $21
4 1 1/2" screw clamps: $4
I ran the power right off the fuse box, so no relay or anything needed. It's too early to tell if this is going to be a good mod, but its pretty cheap and easy to do.
I'll be waiting for dyno results. Any pics coming?
thanks
chris
But then hey, thats a question/test only a dynoqueen like ME would ask <img src="images/icons/grin.gif" border="0"> <img src="images/icons/wink.gif" border="0">
chris
I do not think it will help you much though. What engine are you doing this on, is it a 346?
Check out the discussion Nineball started a few weeks back about timing. If you are already in the 27-30 range I don't think you will see any gain from increasing timing. I would think the car would be less sensitive to detonation though, right?
How much timing does that resistor usually add over say a 85 ambient AIT sensor, 2 degrees?
<strong>The car is pretty low on timing right now, due to 91 octane gas (its a 11.2:1 346), the argument goes if you switch over to reserve flow cooling you might pick up a ton of power with more timing. I don't believe it, but guys argue it. <img src="images/icons/wink.gif" border="0">
How much timing does that resistor usually add over say a 85 ambient AIT sensor, 2 degrees?</strong><hr></blockquote>
Some guys have seen no gain with it, others have seen as much as 2 degrees more. Theoretically the hotter it gets I would think the more of a gain you would see with the TT. What is your timing now? Can you get atleast 93 octane gas for the car?
Good idea, but if it was that simple...I would have converted the same way. You are going to have nothing but problems with the way you set it up, do a real easy test, hold the car at 100 MPH for 1 minuite and tell me what happens. I already lived through all that BS 5 months ago, you will find out real quick, keep a sharp eye on the Temp gauge the whole time or you won't be able to turn the car off fast enough. What going to happen is it's going to run very cool for a while (bad for the rings and makes the motor run rich) then with increased speed all the sudden it's going to overheat. This is why I built my own housing.Then the overflow catch can will do something like this.... <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
[ December 08, 2001: Message edited by: Joe Prince ]</p>
[ December 09, 2001: Message edited by: vt2vx ]</p>
