Found the Culprit!
https://ls1tech.com/ubb/cgi-bin/ulti...c&f=1&t=000764
Anyway got the wires and stuff off...FIRST plug we checked was soaked in gas...obviously not good....took the other three out on the driver side and they were all fine....so we pulled the valve covers off and.....nothing no broken springs nothing.....pulled the intake pushrod off the cylinder that had the wet plug and WHAM i broke a pushrod CLEAN in half it was even bent some at the top......and when it happened i was just cruising driving normally doing about 45 in fourth gear....soo looks like the other piece of the pushrod is down further where we cant get to it...were gonna try magnets and one of thoose little grabby arm thingies to see if we can get the piece....if not looks like were pulling the head <img src="images/icons/frown.gif" border="0"> DAMNIT! ohhwell **** happens i guess...anything else i should look out for??
Thanks for the help
Jay
think there is anything more than a tube
all the way down to the lifter.. I may be
wrong..never have seen down in that far.
Post your results..
Terry
well good luck with it, and you should probably upgrade to newer pushrods, just to be on the safe side... <img src="images/icons/smile.gif" border="0">
Mike
<strong>Well atleast you found the problem Jay. Hey are you still going to do a cam?? Don't worry man you'll be back up and running in no time <img src="images/icons/smile.gif" border="0"> .
Mike</strong><hr></blockquote>
Yeah I'm very glad i found the problem....now we're going to put it back together with a new rod and start it up hopefully(crossfingers) it runs right.....about the cam....hmmm who knows im still tossing the idea around.....i might just save up all the money i get from working and christmas and stuff and buy a 12 bolt <img src="images/icons/grin.gif" border="0">
