I'm doing a hotcam install right now and I have a question
I would. You may as well, whilst your there and you'll never be left wondering. <img src="images/icons/smile.gif" border="0">
I recently replaced mine with 0.308" Shim and seal all in one GM # 12482062 & 12482063.
word..installed new shims..all is better now. thanks. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
I have the rockers off, do I have to remove the bottom valve spring shims? I have 16 new ones that came with the kit and it's impossible to get those bottom shims off with out removing valve seals. Do I need to replace them with the hot cam?? OR can I use the ones that are already on there?
