Tachometer Wire? ASAP???
Old Nov 21, 2006 | 07:06 PM
Sxyman815's Avatar
Default Tachometer Wire? ASAP???
I have an Auto Gage Tach and I have it all wired up but I have no Idea where to run the tach wire... the one that receives the signal from the engine... someone told me it was the 10th white wire on the pcm.... but thats a different car...
Oh and if its on the PCM where and how do I get to it?!
I have a 2002 WS6 PLEASE help its cold out side tonight THANK YOU!!!
Old Nov 21, 2006 | 07:25 PM
2001bluerata's Avatar
I fig. it would be the same... red pcm connector #10 pin/white wire, but it does say 99-00 cars. Anyone know if it's the same on 01-02s?
Old Nov 21, 2006 | 07:28 PM
You'll probably get better feed back in the right section!
Old Nov 21, 2006 | 08:06 PM
ShevrolayZ28's Avatar
It was the #10 white wire on my 2002 Z28. I ran the wire under the dash and out the grommet near the glove box to the PCM.
Old Nov 21, 2006 | 10:23 PM
Sxyman815's Avatar
Thank you very much! Got it ran it under the dash and through the grommet!
THANKS A BUNCH!
Old Mar 16, 2007 | 12:22 PM
Danger731's Avatar
I have the same car, how do I locate this #10 white wire. My PCM has no numbers the connectors all have letters.
Old Mar 16, 2007 | 12:39 PM
c5chris99's Avatar
Autometer.com in the tech section has the wire colors and pin outs. I checked their info with alldata and it was correct for my car. hope this helps
Old Mar 16, 2007 | 12:40 PM
c5chris99's Avatar
oh forgot to mention it is the red connector on the pcm
Old Mar 16, 2007 | 01:12 PM
brad8266's Avatar
White wire #10 on the PCM.
