Anybody running this cam??
Old Dec 10, 2001 | 09:10 AM
sprayinls1's Avatar
Default Anybody running this cam??
224/228 .534/.537 114
I'm thinking about this cam custom grinded with some extra lift. This would be an a4 w/ a 3200 vigilante. Also, can I up the idle from 550 to 825 w/ just the tb drill mod and run this cam w/ stock tuning modified by the hpp3? Looking for some input.
Old Dec 10, 2001 | 01:57 PM
Ragtop 99's Avatar
Default Re: Anybody running this cam??
If the idle speed gets too high relative to the programmed desired speed, you will sometimes throw a code. Won't effect performance, but your SES may be permanently on.
Old Dec 10, 2001 | 02:23 PM
CHRISPY's Avatar
That is a big cam that is going to peak high.
What head setup are you going to run? I wouldnt change the lift unless your heads are ported for higher lift flow.
Cheers,
Chris
Old Dec 10, 2001 | 04:48 PM
sprayinls1's Avatar
Well, I was thinking about getting this cam along w/ the stage 2 heads from IRS www.internetracerssupply.com
The price is the main reason. This would be on a stock bottom end also a daily driver. I already have an ses light due to !cats, so that doesn't matter. This sound like a good setup to where I can go w/o tuning untill ls1 edit comes out for my car?
