Cam degree question
Old Nov 22, 2006 | 04:06 AM
-=Modified=-'s Avatar
Default Cam degree question
When installing a cam do I really need to degree it? I understand anything worth doing is worth doing right. What I am trying to get at is can I degree the new cam off of where the old cam was?
I did try to do a search but my internet sucks here in Kyrgyzstan.
My error
503 Service Unavailable
The server is temporarily busy, try again later!
Powered By LiteSpeed Web Server
Lite Speed Technologies is not responsible for administration and contents of this web site!
Old Nov 22, 2006 | 04:52 AM
~RedLineLs1~'s Avatar
You don't need to but I would degree the cam. It will give you the desired ICL. If you order a custom grind I find it very important to degree the cam. If its off the shelf its a bit more forgiving with the extra advance ground in.
Old Nov 22, 2006 | 06:09 AM
Irocss85's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/610433-degreeing-cam-yes-no.html
not sure if you saw this or not. I say do it.
