Formula to Calculate Displacement?
Old Dec 11, 2001 | 03:37 PM
Y2K_WS6_T/A's Avatar
Default Formula to Calculate Displacement?
I thought it was Stroke X Bore X 3.14 X # of Cylinders?
What is Stock Stroke/Bore?
Old Dec 11, 2001 | 03:45 PM
RyanJ's Avatar
SSU Moderator
Default Re: Formula to Calculate Displacement?
http://www.prestage.com/carmath/calc_cid.asp
or the old fashioned way. its something like:
(PI/4)*(Bore^2)*(Stroke)* 8(# of cyl)
Ryan
Old Dec 11, 2001 | 04:18 PM
1CAMWNDR's Avatar
Stock bore is 3.9"
Stock stroke is 3.62"
The formula I use is an old one.
First find the area of a cylinder: pi( 3.1416) times the radius squared, times the length of stroke.
Then multiply that by 8 for the # of cylinders.
For a stock motor it would look something like:
(Radius for a stock 3.9" bore is 1.95)
1.95 X 1.95 = 3.8025
3.8025 X 3.1416 = 11.945934
11.945934 X 3.62(Stroke) = 43.24428108
43.24428108 X 8(# of cylinders) = 345.95424864"
<img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Dec 13, 2001 | 05:51 PM
Anyone have the Stroke/Bore on a 6.0L Iron Block Motor? <img src="gr_images/icons/wink.gif" border="0">
Old Dec 13, 2001 | 05:55 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Well it would be 3.62 stroke x 4.00 bore =363.92 right?
Using Ryan's link here's my specs...
4.060 bore x 4.075 stroke =422.05ci... so it works. <img src="gr_stretch.gif" border="0">
Old Dec 13, 2001 | 11:35 PM
kewlbrz's Avatar
You can break down the geometry of it, or do it the easy way:
Bore^2 x Stroke x .7854 x #cylinders = displacement in ci.
