K-tech tensioner install help needed.
Old Dec 12, 2001 | 06:28 PM
Swills00Z's Avatar
Default K-tech tensioner install help needed.
Do I need I puller to get stock pulley off of tensioner? Do you think I should remove pulley bolt before removing tensioner and pulley? Thanks!
Swill
Old Dec 12, 2001 | 06:30 PM
Jim98WS6's Avatar
Default Re: K-tech tensioner install help needed.
No puller needed. It just bolts on. It comes off easy so it doesn't matter if you do it on or off the car. I guess it'd be easier holding it if it's on the car.
Old Dec 12, 2001 | 06:41 PM
Swills00Z's Avatar
Thank you.
Once I have the K-teck tensioner on the car with the pulley, how do I tension the belt? Have to pull belt tight then tighten bolt in slider???
Thanks again
Old Dec 12, 2001 | 09:38 PM
Dave F's Avatar
On the corvette version, you insert a 3/8 drive extension into the tensioner and use a ratchet to tension the belt. Then tighten the bolt when in the correct location. You want to get it pretty tight.
Old Dec 12, 2001 | 10:05 PM
Swills00Z's Avatar
Thanks guys!! It went on with no problems. However it did not solve my belt squaele. In fact I shredded the belt! <img src="gr_images/icons/mad.gif" border="0"> Fortunately I was right down the block from my house when this happened, and I dont think I did any major damage! I guess I know why the belt was squealling now - it was bad. Or maybe I mis-routed it when I put it back on <img src="gr_emb.gif" border="0"> ? But I don't think so.
Anyway - anyone know the part number for the Gates belt when you have an SLP underdrive pulley?
Thanks!
